by angib » Wed Nov 09, 2005 7:27 pm
Dale,
Yes, very similar.
A thing I'll add here is that I spent a long time working in shipbuilding and one of the principles was that no welded structure is ever perfectly right. Even if you cut it just right (and steelworkers' tolerances are not the same as engineers' or joiners' tolerances), it will distort when welded. So I would never design the wood to sit tightly on the side of the frame as you've shown - I'd leave a 1/4" gap. Then the floor ply can be cut to the right width and doesn't have to be 'adjusted' to fit the actual width of the frame.
Where the floor sits on the top of the frame is the critical place, since here there is the 'pooling' problem, so a good waterproofing of the floor ply before it is fitted to the frame is required. But as it's side grain, not end grain, that's a lot easier to do successfully.
I'll repeat what I was taught about sealing end grain with epoxy - you should keep feeding the end grain with resin until the resin in your pot starts to gel. Even with fast epoxy, you will get at least two goes at filling the grain, and probably three. The objective is to fully saturate the grain with epoxy and that means you have to keep feeding it - capillary action will draw the first 'fill' away from the end and, if you don't refill, you will get only a partial saturation and that will still be able to soak up water. However this is boatbuilding standard and maybe a bit over the top for a trailer that, hopefully, doesn't sit in water.
Andrew (the pedant)
