Bending Plywood
Bending Plywood
Postby Jim Marshall » Tue Nov 08, 2005 10:30 pm
I have worked with the bending plywood a lot and it can for sure be bent into a tight radius. The down side of using bending plywood is, unless you glue two thicknesses together it will wave and ripple and is not very stable. The 1/8 inch regular plywood will bend to a pretty good radius if it is bent with the grain instead against the grain.
I started out with nothing and I still got plenty left.
VOL-N-TEAR
Jim Marshall
Images: 63
Postby Roly Nelson » Tue Nov 08, 2005 11:05 pm
Well Jim, sounds like you've got that plywood bending and laminating down pat. That is how I built the 1/2 Nelson Woody, and is solid as a rock. I have even bent and glued together, 2 sheets of 1/8" plywood around a 6" plastic pipe, wrapped with many loops of tightly pulled string. However, the last tear I built has only one layer of 1/8" lauan on the roof, but all surfaces are curved and additional curved stringers run from front to back. No problems so far, and it sure is light-weight.
Roly Nelson
Roly Nelson
L'il Ol' Woody Builder
Postby Arne » Wed Nov 09, 2005 7:54 am
Roly, what did you do for walls? The roof with 1/8" and curves is what I'm thinking of using..... I'd like to use 1/8 on the wall with solid foam filler.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby BobR » Tue Nov 15, 2005 4:35 pm
Roly...where are the 1/4 Nelson pics :R
Bob Richert
Parrish, FL
"Be glad of life because it gives you the chance to love and to work and to play and to look up at the stars"
BobR
Postby Jim Marshall » Wed Nov 16, 2005 2:17 pm
I plan to use the 1/8 inch plywood on my sides as well as the top. It should be plenty strong with enough glue and staples with the 1X frame.
VOL-N-TEAR
Jim Marshall
Images: 63
