? under aluminum skin
Postby bobnlyd » Tue Nov 26, 2013 11:26 pm
getting ready to skin my trailer (finally). should i put a barrier in between the skin and the sheeting. i used 7/16" osb with reflective skin on the back (for heat and cold ) and 2x2 framing with 1 1/2" stryofoam insulation...1" plywood subfloor with 3/4" stryofoam insulation and 24ga galv seets as water barrier..roof is 1/4" luan with 1 1/2" insul also...was thinking a 30min building paper would help with any moisture issues
bobnlyd
Re: ? under aluminum skin
Postby George Taylor » Wed Nov 27, 2013 8:15 pm
I just rolled on a few thick coats of spar varnish under the aluminum.
George Taylor
Postby 48Rob » Fri Nov 29, 2013 7:31 am
Most people don't...but many vintage trailer manufacturers did use builders paper between the framing and aluminum skin.
Rob
48Rob
Postby citylights » Fri Nov 29, 2013 7:44 pm
I would paint as a just in case waterproof and wood preservative.
citylights
Postby bobnlyd » Wed Dec 04, 2013 10:56 pm
ended up with 30min paper under and just ordered the epdm for the roof...finishing the doors up this weekend...trying to finish for spring fishing
bobnlyd
Users browsing this forum: Bing [Bot] and 3 guests
