DestinDave wrote:We started out with the fast hardener but mixed up in 1/2 gallon pails it would kick off in about 5 minutes.
Whenever you mix epoxy, or indeed any resin, you want to have flat trays ready to take it - for general laminating work, paint roller trays are ideal and any unused resin will snap out, if the tray is twisted after the resin has cured.
It's a simple volume-to-surface-area ratio deal - increase the surface area by putting it in a flat tray and the resin can't build up heat so quickly and so it won't gel as soon. It's tempting to say dump the resin on the job (for a really big surface area) and then come back and tidy it up when it's all laid out - but in reality, it seems you always miss bits if you do this....
asianflava wrote:Isn't there a difference in strength when it is mixed hot? For some reason, I was under the impression that the faster the cure, the weaker the bond.
Most epoxies have similar, but not identical, strength with all their hardeners, though sometimes the slow or ultra-slow hardeners are slightly less strong.
Most epoxies are proprietary products and most good manufacturers give you proper technical data on line. For Dave's Epiglass, page 48 of the
Epiglass Resin Guide shows the performance is similar, though the wood bond is slightly weaker with the slow hardener.
Since you mentioned 'mixing hot', which is a polyester term, I should add the traditional warning -
do not deviate from the specified resin/hardener ratio for epoxies - this will not alter the cure speed (as it does in polyesters), it will just prevent a proper cure happening. To alter cure speed, a different hardener must be used. If you want to, it is ususally possible to mix the hardeners together to give you a 'semi-fast' or 'slightly slow' hardener, which is then used at the specified ratio.
Andrew
