I'm using MDO plywood, so the faces do not need to be treated, just the joints/seams.
The side profile is ~31', plus ~30' of side-to-side seams, ~4' for the roof vent and ~8' for the air conditioner's hole, so a total of ~104'. I'm planning to use wood screws from the outside into the stick frame to hold the roof panels onto the walls, so 6" wide tape will give me 2" margins for screwing on each side of the joints. Smith's Fill-it will be used to fill any gaps and the counter-sunk screw holes. Afterwards, the entire tear will be covered in two coats of 100% acrylic latex primer, and two coats of 100% acrylic latex exterior paint.
So far, my shopping list is:
1 gallon West 105B epoxy
1 quart West 205B fast hardener
1 pack West 300 Mini-pumps
1 50yd roll of West 733 6" tape, 9oz
2 pints Smiths Fill-it
I know fiberglass won't fold 90 degrees easily, but what round-over do I need? Is a 3/16" or 1/4" radius sufficient between the roof and side wall?
How are my epoxy or fill-it quantities? From West's guide, a 1 gallon kit should be sufficient to fill and coat 50 yards of tape 3 times, but is that a sane amount of epoxy for a teardrop?
