Opinions please - Alum. Edge for joining roof to walls
Postby Tommy2tone_1999 » Wed Mar 19, 2014 5:26 pm
I stumbled on this looking for alluminum edge molding. What's your opinion on using this to join the roof to the walls sealed with silicone instead of glassing the over lap then using the standard edge molding. Any potential problems. I really value your input. Thanks for any help. I found it at this web site http://www.brunnerent.com/Tools/Portfolio/frontend/item.asp?type=9&size=0&lngDisplay=0&jPageNumber=8&strMetaTag= The price for a 12' length is $21.48
Or...
Since I'm building my TD with 3/4" solid walls. Maybe this one
Image for $41.40 (12')
http://www.brunnerent.com/Tools/Portfolio/frontend/item.asp?type=9&size=0&lngDisplay=0&jPageNumber=11&strMetaTag=
Last edited by Tommy2tone_1999 on Wed Mar 19, 2014 5:52 pm, edited 1 time in total.
Make time for fitness and it'll make time for you.
http://TommyDoran.com
http://tommydoran.com/favor
Interview: http://goo.gl/Non1oR
Build Journal - http://www.tnttt.com/viewtopic.php?f=50&t=58395
Come find me on Facebook - http://www.facebook.com/tommy.doran
Tommy2tone_1999
Re: Opinions please - Alum. Edge for joining roof to walls
Postby rowerwet » Wed Mar 19, 2014 5:52 pm
aluminum shrinks and expands at a much different rate than wood, keeping the seal water tight over time could be and issue, even with the silicone caulk. I can see using this for edging around doors and stuff, but at the joint between two walls you would do better to have epoxy, polyurethane adhesive (what I used), or just silicone caulk and a block of wood inside to seal the seams.
rowerwet
Images: 521
Postby Tommy2tone_1999 » Mon Mar 24, 2014 1:30 pm
Makes sense. Thanks!
Tommy2tone_1999
Postby Greg M » Mon Mar 24, 2014 8:46 pm
It'd be impossible to bend if you have any curved sections.
Greg M
*Geek Extraordinaire
Images: 85
