Page 1 of 1
Opinions please - Alum. Edge for joining roof to walls
PostPosted: Wed Mar 19, 2014 5:26 pm
by Tommy2tone_1999
I stumbled on this looking for alluminum edge molding. What's your opinion on using this to join the roof to the walls sealed with silicone instead of glassing the over lap then using the standard edge molding. Any potential problems. I really value your input. Thanks for any help. I found it at this web site http://www.brunnerent.com/Tools/Portfolio/frontend/item.asp?type=9&size=0&lngDisplay=0&jPageNumber=8&strMetaTag= The price for a 12' length is $21.48
Or...
Since I'm building my TD with 3/4" solid walls. Maybe this one
Image for $41.40 (12')
http://www.brunnerent.com/Tools/Portfolio/frontend/item.asp?type=9&size=0&lngDisplay=0&jPageNumber=11&strMetaTag=
Re: Opinions please - Alum. Edge for joining roof to walls
PostPosted: Wed Mar 19, 2014 5:52 pm
by rowerwet
aluminum shrinks and expands at a much different rate than wood, keeping the seal water tight over time could be and issue, even with the silicone caulk. I can see using this for edging around doors and stuff, but at the joint between two walls you would do better to have epoxy, polyurethane adhesive (what I used), or just silicone caulk and a block of wood inside to seal the seams.
PostPosted: Mon Mar 24, 2014 1:30 pm
by Tommy2tone_1999
Makes sense. Thanks!
PostPosted: Mon Mar 24, 2014 8:46 pm
by Greg M
It'd be impossible to bend if you have any curved sections.
