Mike!
Thanks for the come back. It's encouraging that you at least see what I have to work with to make my tear easy to build.
This material is to be used on the main top roof as well as seen by the bottom drawing and yes it will reach the wood. I also can use diffrenet screws which will have screw caps over the screw heads. Sealed with silicone, leaks will be non existance. Also adding another screen cap over the screws atop the roof shating, I can cover the screws on the top as well as the sides. Or anywhere on the tear for that matter.
This lip is wide enough to have a screw head 3/8 " wide screw screwed through it. Here is a photo of the screw in the vynal lip. Remember the color/cocoa is what I have now showing in the picture. I think I will go for almond on the whole trailer as an outside theme when I make it. I am actually getting all the material now. But want to build it once I have everything collected. I will have great building shots as I have a great camera as you can tell by these shots. By the way the trailer you saw previous, is tested this vynal without screws as I drove up and down the turnpike at speeds of 60 mph. Non of the vynal came flying off the alum. Notice two pieces of alum clamped by the vynal without screws.
Here is a drawing of how it will be used on the top.
Long time researching the abandoned South Pennsylvania Railroad along the Pennsylvania Turnpike. God will guide me. As he has done so in the past. southpennrailroad.com
