1# Glue and bag the floor and side panels
2# Cut the inside profile on the inside or the wall panels leaving the outside FRP run wild. Making a step for the floor and the roof to set in. Floor step could be formed in step 1#.
3# Glue the walls on to the floor.
4# lay plastic sheet over the walls to make the inside of roof vacuum bag.
5# Lay the ceiling FRP over the walls in the step in the walls, glue, put in the sloted (to bend) polystyrene,glue, FRP. Lay the plastic sheet over the top. tape and vacuum with ratchet straps holding it to the walls.
6# Remove the bag and glue down the roof with the polyurethane chalk.
7# Cut the doors and hatch off.
8# Glue FRP strips to the cut edges.
9# Mount the door and hatch with glue and bolt that go thru. The inside would be drill bigger for a spacer tube with a fender washer on the inside.
What glue would be best? Any thoughts? Am I crazy
Like I said at the top of the post Just brain storming.
