Does silicone go bad?
Be patient. Remain optimistic.
Gus
Gus
BillZ wrote:Ugh!
Besides the fact that I don't know if turpentine will hurt the surface.
I wonder if scraping the worst of it off and the new pressed into the old will bond and cure?
Breytie wrote:BillZ wrote:Ugh!
Ouch, that is a real bummer. Normally turps does not attack cured finishes, but always test first in an inconspicuous spot.
Are you sure the turps will remove the uncured sealant? I use a sealant remover from SOUDAL that contains some citrus oils and it makes even cured silicone and acrylic water removable.
The bad sealant will stop the good stuff from adhering properly and may even slow or mess up the cure. Scrape and rub off as much as you can and then use the recommended solvent to wash away the rest.
I hope the manufacturer or seller will replace the bad stuff?
I hope this turns out good!
