absolutsnwbrdr wrote:Your mattress will work as floor insulation. You'll be fine.
woodywrkng wrote:Be careful with that "thinking" business. No good can come from that. (sarcasm intended) I think you'll be fine. Any moisture that sneaks in should escape from the roof vent.
48Rob wrote:Derson,
In a normal camping scenario ground moisture isn't going to be an issue.
If you store the camper in a wet area and the exterior of the floor isn't well sealed, the moisture may become a problem.
As for when you are camping, airborne moisture may become an issue in cold weather, as it will want to condense on the coolest surfaces.
The mattress, as pointed out will "insulate" the floor, but if there is space around the edges of the bed, moisture can condense there, and then soak into the bedding.
For most campers, it isn't an issue, but if you forsee a lot of cold weather camping, a thin layer of insulation on or under the floor isn't a bad idea.
Rob
