tony.latham wrote:Are you sure you want to glass after the fender is mounted?
I will epoxy coat the whole fender prior to installation. The part I was going to glass after mounting is just the underside (inside) of the wheel well and applied fender. If you look closely at the picture you can see there is a built in wheel well under the camper. The fender only extends 4 inches beyond the camper wall.
The existing wheel well is made of 3/4 inch plywood and already has a couple coats of epoxy. Even after the few trips I have taken I noticed there are some stone chips that have penetrated the epoxy, leaving the plywood exposed to moisture. I thought the glass and epoxy would provide much better protection than epoxy alone. Yes it will tie the inner wheel well and fender together, but I thought it would be pretty easy to cut along the seam and free the outer fender from the wheel well if needed.
Am I missing something or just overthinking this?
KCStudly wrote:A buddy of mine has a technique he uses for thru penetrations on his boat (fiberglass over wood). First he marks out his holes, then drills them over size by a fair amount. Then he fills the hole up completely with thickened epoxy (or resin) and fairs it back out. Next he drills the hole to final size, usually a slight clearance hole for the bolt size being used. This leaves no doubt that the hole is completely sealed and it is also reinforced. Finally, at assembly he seals the bolts and fixture with deck sealer.
On the underside, I would just use a nice flexible exterior grade latex sealer (paintable, not silicon) between the fender and wall, then go back and smear the squeeze out (or apply some of the same) over the seam to eliminate any crevice. That way if you ever have to pull the fender you can cut thru it with a razor knife or a fine wire.
Neat process for the bolt penetrations. I might give that a try.
Good call on the latex sealant. I used one on the galley hinge for the maiden voyage then removed the galley again for some finish work. I thought I would be able to easily pop the hinge off after the screws were removed but no amount of pulling, banging and twisting on the galley lid would release it. It took driving a putty knife under every square inch of the hinge to release it! I think I could have driven around all summer with just the latex sealant holding the galley lid in place.
