Page 1 of 1
Top Skin
PostPosted: Thu Aug 21, 2014 11:43 am
by ocasioc25
Hello all,
I am building on a 5x8 trailer. Since I have 60" on the inside of the trailer, that makes the walls 1.5" thick. Now I have 63" wide from front to back. I did manage to find 5'10' aluminum which will cover the sides perfectly. Is there a way to place the skin with out having a strip going across the roof? Or is there a over the edge trim at least 2" wide? I was thinking placing the 5'x10' from the from to the back and then a long 3" strip along side it. That or a strip across. Stuck here and have no clue how to make this work. Any suggestions would help.
Thank you
Carlos
Re: Top Skin
PostPosted: Thu Aug 21, 2014 1:18 pm
by KCStudly
You could set the wall on top of the trailer rail (or floor) and just have the thin outer skin drop down to cover the frame (if that is what you want... my cabin sits fully on top of my frame with nothing sticking down).
If you use 1/4 ply outer skin (which IMO is more than adequate) you should be able to find trim that will cover the difference. If you are looking to maximize interior room an option would be to step down to 3/4 inch core for your walls (i.e. 1x2's studs in the flat instead of on edge, or skeleton plywood).
$0.02
Re: Top Skin
PostPosted: Thu Aug 21, 2014 3:48 pm
by grant whipp
Carlos!
If you've already built the cabin and are stuck with the 63" overall width ... find a local (or semi-local) tractor-truck trailer repair facility and purchase some 103" wide .040" aluminum that they use to replace the roofs of the big semi-trailers ... you'll have a little over 3' of off-fall, but you'll find a use for it some place, some time ... ;) ...!
Good Luck, and as always ...
CHEERS!
