mikefree wrote:Thanks. Is there a downside? I was thinking of skeletized ply and skinning both sides for weight but it doesnt seem like you'd peel enough weight off for the labour you'd put into it.
Hi, Mike!
No real downside to it, as long as you carefully plan your entire construction around it. "Skeletizing" the walls IS an option, and it's how
I build all of my teardrops (39 and counting) ... yes, it is more work than using a solid wall, but much less work that "stick framing" and much stronger, and you do get the added benefit of extra insulation space ... it's a compromise, like everything in teardrops is a compromise, and it all boils down to the amount of work you want to expend and the desired overall quality & finish of the end product.
However you choose, Good Luck ... we're all here to offer advice & guidance ...
CHEERS!
Celebrating
Retirement after over
32 Years of Building, Promoting, Supporting, Supplying, Living the Lifestyle, and Loving
Teardrop Trailers!"Life Moves a Little Slower When You're On Teardrop Time"The nature of Life, itself, is change ...
"Those who matter, don't mind, and those who mind, don't matter."
