1. get some 8 1/2 x 11" sheets of Carbon Paper (the shiny stuff works best)
2. Get some regular 8 1/2 x 11" printer paper.
3. Place a piece of carbon paper ontop of a piece of printer paper (copy side tword the paper)
4. Now with the Tear loaded roll it across the carbon paper and look at the pattern that the tire made on the paper. If the pattern is darker on the edges then you'll need to add pressure to the tires, if the pattern is darker in the center then you'll need to decrease your tire pressure.. Once you get an even pattern all the way across then make note of your pressure and your done.... This should help with ride quailty and keep an even tire wear...
Greg
