at .37 there was a gluing surface of .26 left over.
at .46 there was a gluing surface of .37 left over.
at .71 there was a gluing surface of .63 left over.
so on average you lose about .09 inches of material from the .12 roof panel
any strength you lose from plywood joint would be more than compensated by using fiberglass tape to reinforce.
took in account for a .71 interior and a .12 exterior with a .12 roof. same 1/2 inch roundover many of the cookie cutter profiles use this setup.
