Page 1 of 1
radius corner window
Posted:
Sun Dec 04, 2005 6:31 pm
by surveytech
Question for those who have used the radius corner windows in their tear.
Could you mount these without the clamp ring?
My wall are only 1/2" and the only rings I have found are for 3/4 and 1-1/2 inch walls.
Maybe drill through the face of the frame to mount them?
thanks,
Walter
Re: radius corner window
Posted:
Sun Dec 04, 2005 6:57 pm
by Kevin A
surveytech wrote:Question for those who have used the radius corner windows in their tear.
thanks,
Walter
Have you considered using a 1/4" wood moulding/trim piece under the inner ring? I had the opposite problem, my walls turned out too thick for the ring so I did as you suggested and drilled mounting holes in the window frame itself to mount the window.
Posted:
Sun Dec 04, 2005 7:02 pm
by madjack
we also drilled holes in the outer frame and "blacked" some screws for mounting directly since we didn't care for the look of the ring(cheesy)...I had contacted the distributor and they told me they also did this...
Posted:
Sun Dec 04, 2005 7:58 pm
by DestinDave
I had been wondering the same thing. Thanks for the input Kevin & MJ. By the way, I've looked at several suppliers and most are pretty similar in quality and price. I want 12hx18w dark sliders. Any recommendations on a particular model or supplier?
Thanks, Dave...
Posted:
Sun Dec 04, 2005 8:02 pm
by surveytech
Kevin.....I realize I could trim out the door to get the proper thickness.
Not sure if I want the trim rings though.
Maybe I need them though to just finish it off on the inside.
not sure.
Jack.........how did you trim the windows on the inside if you didnt use the rings?
Dave........I think lowcost trailer supply has them for about 45 each and freight for two on their automatic check out to florida brings it to about 100 bucks delivered for two windows.
maybe others have found something better.
Guess I am just looking for options.
thanks!
Posted:
Sun Dec 04, 2005 8:32 pm
by SteveH
I used the radius slider window with the trim rings, but did not like the way the trim ring installed either. So, I used screws thru the rim of the window to mount and then the trim ring is just that, a trim.
Posted:
Sun Dec 04, 2005 8:42 pm
by Greg M
Couldn't you just cut down the trim ring? If they're just an aluminum ring with an inside flange like I assume they are, then you should just be able to run them through a table saw.
-Greg
Posted:
Sun Dec 04, 2005 8:54 pm
by Gage
I had somewhat the same problem with my sun roof. Roof thicker than the sun roof. What I did was attach the sun roof to the outer skin and ply and then installed the ring with the outer skin wedged in between. Then added the bracing and inner skin. Both routed around the complete window which in turn gives me a flush fit. Picture below isn't that good but maybe you'll get the idea of the end result.
Have a good day.
Posted:
Sun Dec 04, 2005 9:21 pm
by Nitetimes
Gage - Did your sunroof have a slight bow to it? I pulled an electric rollback one out of a Pontiac and it has a bit of a bow to it, (actually the glass is pretty flat mostly the frame's bowed) I was wondering if anyone else used on that was bowed. I know most car roofs are and that's where most of them come from. I want to use this one in the next one, already figured out how to trim the inside with a screen in it so that's not a problem, it's just sealing the bow that concerns me.
Posted:
Sun Dec 04, 2005 9:26 pm
by doug hodder
While you already have the radius windows with the slider it really doesn't matter...however....there is an advantage to the crank out windows....they don't allow water to come in when it is raining, not the same look however.......but I'd agree with some of the other replies...just cut down the ring on the outer portion....I've done it using a good variable speed jig saw...don't get in a hurry and let the saw do it's work....get the correct blade also...just my opinion....Doug
Posted:
Sun Dec 04, 2005 11:09 pm
by Gage
Nitetimes wrote:Gage - Did your sunroof have a slight bow to it?.........
Yes, it had and still does have a slight bow ('73 Chevelle). One reason I located the sun roof before I located the two cross frames for & aft of the sun roof. My roof is 1/8" ply and .062 alum. When I installed the inside ring with the factory screws it sucked the ply and alum up tight. From the outside, you can't hardly tell there is a bow. And it doesn't leak.
Did that answer your question? Have a good day.
Posted:
Sun Dec 04, 2005 11:43 pm
by madjack
surveytech wrote:Jack.........how did you trim the windows on the inside if you didnt use the rings?
thanks!
...we used a 1/2 wide vinyl "T" molding around all of our cabinet doors(door edge and jamb)...we also used it several other places including the windows...it fits and looks great...since we haven't finished the doors i don't have a pic of how it worked out but if you click my www button and look at the galley album and "T" molding you will see it...it is aluminized and there is a protective tape onit...I got mine from tjtrailers.com but they are a distibutor for RedNeckTrailer Supplies and I found I could get them cheaper from my local welding supply house who also is a RedNeck dist. and not have to pay shipping for them...mine were 18x24. locally they were $48 bucks a pop
Posted:
Mon Dec 05, 2005 1:13 am
by Nitetimes
Gage wrote:Nitetimes wrote:Gage - Did your sunroof have a slight bow to it?.........
Yep, that's what I was uncertain of so I'd think mine will work just fine. That should make the wife happy, she really wants one in the next one.
Thanks, Rich
Posted:
Mon Dec 05, 2005 3:25 am
by surveytech
Jack,
I like the vinyl T molding idea. Thanks.
I know my skills and I dont think I would be able to trim that aluminum trim ring to have it look right. I dont have a table saw and my guess is that I would have lots of "waves" in the aluminum with a jig saw .
perhaps I am just being paranoid.
The vinyl comes in colors too I think. That would be good to keep it all color co-ordinated inside. That should keep the misses happy and we all know how important that is!
Thanks for the input everyone!
Walter
Posted:
Tue Dec 06, 2005 4:59 pm
by sunny16
I sure am glad that this forum is here. I have been wondering how to trim out my windows, too. There will be a "gap" between the outer frame of the window and the inner trim ring. I was thinking of a strip of foam around the inside of the two but the t-molding ideas sounds like it might work AND look better. If anyone has trimmed thiers with t-mold and could post a picture I'm sure it would help to see the outcome.
If I read here enought all of my questions might just be answered! BTW I got my windows from a truck topper manufacturer in town. They are tilted but will work for what style of tear I am building. They had lots of sizes to choose from and they gave me a good price on them. Sliders and tinted.
