How to seal/trim bottom of walls
Postby javajaws » Fri Nov 28, 2014 8:28 pm
I'm in the design phase of my teardrop build and haven't been able to come up with a good answer for this:
My walls will extend to the top and sit flush with the top of the frame - basically the frame will be visible once the walls are complete and sheathed with aluminum. I know to seal the bottom edges of everything with Epoxy - but I have seen some builds and manufacturers put some kind of aluminum trim along the bottom as well, like the Moby 1:
Any ideas what to use down there? I want to make sure that bottom edge gets sealed up nice and tight, but without extending the aluminum down to cover the frame (for aesthetics mostly).
javajaws
Re: How to seal/trim bottom of walls
Postby tony.latham » Fri Nov 28, 2014 9:46 pm
Use some of Grant's edge trim. http://www.teardrops.net/teardroptrailerparts.html
I don't recall if the trim on the bottom is 5/8" or 3/4":
T
Postby javajaws » Sun Nov 30, 2014 10:38 am
Which edge trim are you referring to? Is this a flat trim or more of an L shape (tucked under the wall slightly)?
javajaws
