Drewjharper1900 wrote:Hey guys! So I am a first time TD builder and I have a few questions. I have been trolling the forum for the past few weeks and theres a few questions that I haven't been able to find answers too.
Hey, Drew!
Welcome to the sandbox!
1. I am building a cubby 5x8 on a northern tool trailer. I will not be skinning the camper. My plan has been to construct my walls with an outer sheet of plywood, spars with foam in-between, and an inner sheet. What thickness plywood do you guys recommend for the inner and outer sheets? 1/4" or 1/2"? As well, are 3/4" spars sufficient for the walls and roof? or should I use 1"?
That kind of build method is typically referred to as "stick framing" and can be a very light weight way of building a teardrop! Usually, the framing is 1x2, with the 3/4" being the thickness, and 3/4" foamboard for insulation ... 1/8" is fine for the interior, but there's really no reason to go any thicker than 3/8" for the exterior sheathing, and 1/4" is actually fine!
However, one of the things that few people think about when starting on their build is the aluminum molding you will (or won't) be using to trim the door and door opening and galley wall tops, as well as which kind of door hinges you will be using. You should make the overall thickness compatible with what ever is available, or be willing & able to cut something wider down to fit. As well with the door hinges ... for instance, the custom-formed door hinges that I make & sell can't be bent for thicknesses of more than 1", and if you will be using T-Molding on your doors, you should really consider some way of offsetting the door 1/8" outward so that it will seal evenly all the way 'round (a simple 1/8" spacer on the body side mounting of the hinge will usually suffice).
Regarding the roof spars, on a 5' wide trailer I would suggest a thickness of 1-1/2" ... I would typically use 2x2s (1-1/2" x 1-1/2") on approx. 16" centers (no real reason to go any closer on spacing).
2. For the roof, what thickness plywood should I use for the outer layer(s)? There is no Baltic birch in my area. But there is 5.2mm White birch. Is that comparable to Baltic birch? Also, is 5.2mm the same as 1/4" or is It a little thinner? Or should I go the route of 1/8" luan? If I did use luan, is 1/8" sufficient or do I need to use 2 layers if 1/8" since I wont be skinning it?
I think you'll find it a whole lot easier to get the wood around the curves if you use two layers of 1/8" ... be sure to run the "grain" side-to-side so it will take the bends that much easier!
3. What process would you recommend for sealing/painting the TD?
That will depend on the overall finish you are after ... if you want a really nice-looking woody, the best and most maintenance-free method is a couple of coats of clear epoxy followed by three-or-more coats of automotive clear ... if you are looking for something inexpensive and purely functional, then smoothing and filling and sealing and finally painting with at least two coats of exterior latex paint will work just fine (if it's good enough for the wooden workboats of the Northeast, it'll be good enough for a utilitarian teardrop ...
Sorry for all of the questions. I appreciate any input that you guys have for me!
No problem ... that's what we are all here for ...
...! Good Luck on your project, and as always ...
CHEERS!
