TomS wrote:I have a aluminum saw circular guide I picked up a one of the big box stores for $15.
Karl Stevens wrote:I'm sure I'm not the first person on the planet to think of this, but I used a handy little trick recently to make precision, straight line cuts with my hand-held rotary saw. I was cutting tongue and groove paneling for my basement, and it was critical to have perfectly straight cuts.
I marked my line to cut and clamped a piece of hook strip (the stuff shelves rest on in your closet) to the panel. I measured the blade and guide on my saw, and clamped the hook strip the appropriate distance from the line. Then I butted the saw up against the hook strip and used it as a guide as I cut the panel. The result was a perfect straight line cut with no wiggles in it. This would certainly be useful in cutting long straight lines for teardrop construction rather than depending on a steady hand and clear view of the line.
cracker39 wrote:Jack, kudos to your partner. That's a good tip. I'm gonna set one up.
