by lesabret1 » Wed Jan 07, 2015 1:18 pm
Hi,
New member here.
Didn't know whether to post this in the trailer/chassis section or general construction section, but here goes:
I'm having a teardrop built and it won't be the lightest one around.
I am thinking about the trailer, detached from the tow vehicle, on enough of an incline to either start rolling like a shopping cart in the parking lot, or
just being difficult to easily stop when I am rolling it around by hand.
I am curious as to how many of you with small trailers (doesn't have to be a teardrop) also have handbrakes or parking brakes on your trailer.
Mine will have electric brakes, able to be controlled from the tow vehicle with an electric brake controller wired into the umbilical between vehicle and trailer.
I've only seen mention of hand brakes maybe two or three times on various forums and the thread never went into detail on the setup or activation.
I got the impression that most were like traditional car parking brakes, a mechanical system controlled by a cable going to a set of brake shoes inside the trailer wheel(s).
I started thinking about whether an electric setup might work using the same sort of variable voltage signal that comes from the tow vehicle, only actuated by a switch or potentiometer located in a handy position in the tongue area. Thought is to parallel the brake signal wire from the tow vehicle connection with a spiral cord (like an old telephone cord; remember those?) and have a connector in the tongue box (where the rest of the batteries and power system resides) that I could plug into when manually moving the trailer and be able to "step" on the brakes with a hand control. Might this possibly work? Don't know the current required by the electric brakes, but the wires are not huge.
If anyone has pictures of their hand brake setup, please post them if not too much of an imposition
Much appreciated in advance,
Dave
