Spar Thickness
Spar Thickness
Postby Diemjoe » Thu Feb 12, 2015 2:02 pm
I was wondering how much trailer width affected the thickness of the Spars. I was thinking of glueing 2 pieces of 3/4 plywood That are 2 inches wide to match the insulation thickness. Trailer is just shy of 5' wide. Wall are 3/4" skeleton with 1/4" skins on both sides.
Don Miller
Seattle
Trippinwithdon.com
Diemjoe
Re: Spar Thickness
Postby aggie79 » Thu Feb 12, 2015 3:44 pm
I used single 1x2s on edge (1-1/2" x 3/4"). Spacing was 16" o.c. except at vent fan. I also double up the vent fan spars to allow "meat" for the fan fasteners. In the curves, the spar spacing was tighter.
Re: Spar Thickness
Postby Diemjoe » Thu Feb 12, 2015 3:47 pm
aggie79 wrote:I used single 1x2s on edge (1-1/2" x 3/4"). Spacing was 16" o.c. except at vent fan. I also double up the vent fan spars to allow "meat" for the fan fasteners. In the curves, the spar spacing was tighter.
What type of wood were your 1x2's?
Don Miller
Seattle
Trippinwithdon.com
Diemjoe
Re: Spar Thickness
Postby angib » Thu Feb 12, 2015 4:31 pm
Diemjoe wrote:I was thinking of glueing 2 pieces of 3/4 plywood That are 2 inches wide to match the insulation thickness.
Remember that only half the plies in the plywood will run from one side to the other - the rest will run up and down and provide no extra strength. A decent 1x2 would be as strong.
angib
5000 Club
5000 Club
Images: 231
Re: Spar Thickness
Postby Jdw2717 » Thu Feb 12, 2015 7:29 pm
I ripped 2x4x8s in half to get the spars at 1.5"thickness for double foam isulation layers. Any water intrusion will not cause the weakness that delamination would bring if water ever got inside the structure. Install with any existing bow facing up. I believe plywood would be a little heavier also.
"Twenty years form now you will be more disappointed by the things that you didn't do than by the ones you did. So throw off the bowlines... Explore. Dream. Discover" Mark Twain
John & Tatanya
Jdw2717
Images: 34
Re: Spar Thickness
Postby coyote » Thu Feb 12, 2015 7:54 pm
I to ripped 2x4s and used them. ( too long working on caterpillars, I put them every 8 inches front to galley, slight overkill I think) coyote
coyote
Titanium Donating Member
Re: Spar Thickness
Postby jonw » Thu Feb 12, 2015 11:59 pm
Poplar 1x2s on edge worked well for me
jonw
Images: 163
Re: Spar Thickness
Postby aggie79 » Fri Feb 13, 2015 9:31 am
Poplar. The big orange and blue box stores usually carry poplar. Pine will work too but you need to be careful with using screws. You can over-torque screws more easily in pine.
Re: Spar Thickness
Postby Diemjoe » Fri Feb 13, 2015 10:21 am
Thanks everyone. I am going to go out and get Poplar this weekend then.
Don Miller
Seattle
Trippinwithdon.com
Diemjoe
