Great way to steam bend wood
Postby daveesl77 » Sun Feb 15, 2015 6:47 pm
While coming up with designs for how the outside of the trailer will look I've been pretty set on doing a steam bend on the outer rails. It has been a few decades since I bent wood, but I always figure the methods are the same. Build a steam pipe, heat water, wait, try not to burn yourself too bad. Well, here is a fantastic method of steam bending wood while maintaining the shape since it doesn't cool in a transfer process. Leave it to an old wood boat builder to come up with this. You can make the plastic "bag" by either using 6mil poly and melting it to form a bag or someone suggested possibly using those seal a meal bag rolls. Don't know how long they are or the cost.
Anyway, check this out, it is brilliant!
https://www.youtube.com/watch?v=--iPQIwSEJM
dave
daveesl77
Images: 273
Re: Great way to steam bend wood
Postby lrrowe » Sun Feb 15, 2015 8:11 pm
Very clever.
Bob
lrrowe
Images: 439
Postby Pmullen503 » Mon Feb 16, 2015 8:38 am
Here's a source for the tubing. http://www.uline.com/BL_2107/4-Mil-Poly-Tubing
Pmullen503
Images: 67
Postby ctstaas » Mon Feb 16, 2015 10:38 pm
Hi All, That is a great idea and so simple. I will use it on my next steam bent project. The problem I have with steam bent wood is it will unbend. Another idea for bent wood I have used is to cut 1/8" strips and laminate many together in the correct shape and then sand to the finished shape. As with any process the solutions haven't been discovered yet and overcome with imagination.
Enjoy, Chris
ctstaas
