Pressurized Water System
Postby Roberto » Tue Dec 13, 2005 10:18 am
Thinking of making a water supply system out of 4" PVC. It would be Sch. 40 and about 8 feet should give me 4.75 gal. I would mount it to the bottom of the trailer.
Has anyone tried to supply the water by adding an air valve (tire type) and pressurizing the system to about 60 psig with a tire pump?
As soon as the water press. starts to drop- - - -pump it up a little more.
Thoughts please.
- - - - - Bob
Roberto
Postby madjack » Tue Dec 13, 2005 10:31 am
Bob, click on my WWW button to see how we used 4" PVC for a water tank...it is not pressurized but rather we are using a cheapie jc whitney 12V water pump that screws directly into the pipe...the entire unit will also be mounted underneath, between the rear crossmembers...the unit is a little over 7' and will hold about 4.5+ gals...
p.s. the problem with adding air directly to the system. to pump water out, is that everytime you pump air into it, you will be adding contaminates from the pump...the air coming from a tire pump is not clean...unless filtered between the pump and tank...commercial systems that work thataway have a bladder in them that is filled with air and that bladder forces the water out...
Postby Roberto » Tue Dec 13, 2005 10:49 am
Madjack,
Looked at your pics, that's exactly what I had in mind. I wanted to pump up the pressure because I didn't want the expense of a 12v water pump - - they're expensive.
I surfed JC Whitney for a pump and the only thing I could find was a Shurflo 12v pump for $220 - - that's a deal killer for me.
Would you be able to try and find where you got the cheepee and about how cheap?
thanks,
- - - Bob
Roberto
Postby madjack » Tue Dec 13, 2005 10:53 am
...try this one ...25 bucks for pump and faucet...cheap enough...don't know how well it'll last but....it is cheap
Postby Sonetpro » Tue Dec 13, 2005 11:03 am
I got a sureflo off ebay for $50. That is a super idea. I have a 10 gal I'm using onboard in the galley. But that's a great idea for gray water storage to be in compliance with the State parks.
Sonetpro
Images: 107
Postby madjack » Tue Dec 13, 2005 11:06 am
Sonetpro wrote:I got a sureflo off ebay for $50. That is a super idea. I have a 10 gal I'm using onboard in the galley. But that's a great idea for gray water storage to be in compliance with the State parks.
...if you go with 6" in the same length, it will give you almost 10gal of storage capacity...I had thought about it for grey water also...
Postby Roberto » Tue Dec 13, 2005 11:16 am
Madjack,
Thanks - - - Don't know how you found it,- - - I surfed the same site and couldn't find it.
I think I will give it a try.
- - - Bob
Roberto
Postby madjack » Tue Dec 13, 2005 11:27 am
Roberto wrote:Madjack,
- - - Bob
...click on RV first, then search for waterpumps...a warning...that pump is not self-priming, so it must be at the level of the water or below...
Postby Roberto » Tue Dec 13, 2005 11:35 am
Details- - - Details !
Only kidding, I guess that would pose a problem unless I mount the pump under the trailer also. I assume it could give a "lift" of 24" to the faucet.
- - - Bob
Roberto
Postby madjack » Tue Dec 13, 2005 11:50 am
originally we were going to mount the pump inside the galley...untill we found out it is not self priming...since the "barb" on the pump is threaded, I think we will just screw the pump into the tank...pumping up to the faucet should be no problem since that is what it's designed for...
p.s. the devil is always in the details ;)
