Side Wall Overhang
Side Wall Overhang
Postby RLG-GSG » Sat Feb 21, 2015 5:58 pm
Good day all,
Just a quick question for the Pro's...
Per my sketch, is a 5'' overhang potentially a problem with TD strength?
Thanks,
George
Overhang
RLG-GSG
Images: 5
Re: Side Wall Overhang
Postby daveesl77 » Sat Feb 21, 2015 7:26 pm
I am by no means a pro and am in fact a rookie in TD building. However, I've built a lot of other stuff over the many years. With mine my floor overhangs the trailer frame 7" on each side and 12" on the back. I way, way overbuilt my floor doing 1/2 ply then a 1" framing filled with foamboard and another 1/2 ply. I weight 220 and can stand and bounce on the far, unsupported corner without any noticeable spring or movement. I flipped it over twice today while doing my waterproofing and it is like flipping a sheet of granite, no bend at all. I calculate it weighs about 170lbs.
Strength in a cantilever comes from the material composition and overhang vs supported length. Not sure what your floor composition is, but guessing it is 3/4" multilayer plywood. Just saying with my laminated system it could probably withstand a 24 inch overhang.
dave
daveesl77
Images: 273
Postby RLG-GSG » Sat Feb 21, 2015 7:46 pm
Thanks Dave,
I was planning to use a composit floor of 1/4" Ply, 3/4'' frame with foam insulation and a final 1/2" floor board. Probably similar to your only with the 1/4'' on the bottom.
George
RLG-GSG
Images: 5
Postby Nobody » Sat Feb 21, 2015 7:53 pm
RLG-GSG wrote:Good day all,
Thanks,
George
Nope. My 5'X114" has a 6" overhang on each side & several inches front & rear. Built it in 2006, & 25K+ miles later over about every kind of road/terrain you can imagine, & a rear end collision in 2010, the overhang ain't caused any problems...
This pic made last week - still don't look bad -
Harvey -
Nobody
Images: 342
Postby RLG-GSG » Sat Feb 21, 2015 8:09 pm
Thanks Harvey,
That's about what I'm designing right now. I plan to use the frame from a rather tired Palamino Colt popup. Actually all that's left is the frame.
George
RLG-GSG
Images: 5
Postby daveesl77 » Sat Feb 21, 2015 9:48 pm
Hi George,
Yours will be fine. If I build another, I will definitely lighten the floor build. However, having a really strong foundation (even if overbuilt) doesn't hurt too much. After seeing how mine came out, I'd have no qualms dropping to your sizes at all.
Harvey, that is a NICE build! Very similar in shape to what I'm doing.
dave
daveesl77
Images: 273
