Javajaws- I dont know where to get any other aluminum. I got mine at cost before my brother sold his sign business. Even then I think I could only get mill finish or it may have been to costly for me so I got painted.You may check a sign shop in your area.
So the tinkering around with the roof aluminum continues. We looked at our teardrop and the breaks/seams (if ran side ways) would end up on a curvy part no matter how we do it. Or One can go on the flat area. None of the options look like a good place to have a seam. So we laid it longways and it lays right at 3/4 from the wall all the way down both sides except in one place. The trim would only hold 1/4 inch on each side of the aluminum. In the one spot about 1/8 under.
So we continue to look and think
Looked for wider trim. Ours is 1 1/8 insert type.It only lays about an inch onto roof. Considered a new 5x10 piece of aluminum. Anyone want to put in two cents? Am I worrying about where those seams end up too much?
I sealed the top with silicone where the roof and wall meet. Then we did a cloth and tightbond II over the corner. The walls and roof have the 50/50 poly/mineral spirits mix on them. So that is done and feel better that it will be water resistant under the skin. But I really don't water to get that far!
Thanks in advance!
Kim
Here are some pics of the mess! It is all temporarily in place, except the silicone and canvas anyway...
glued canvas shows wall side
silicone in the one wide gap before canvas is on
trim over alum laying in place
silicone is in crack like this everywhere else
canvas over top edge with aluminum laying in place
I am going to see if the hubby will help me put the aluminum the other way and take pics of where the seams would end up across the top. meanwhile feel free to send links of 5 wide material in MO LOL
