Glue for wood-to-wood - Hardening or Non-hardening
Postby DougN » Sat Mar 14, 2015 1:22 pm
My local plywood supplier suggested that a non-hardening glue would be better as hardening glue can cause plywood delamination over time due to expansion/contraction /vibration of the sheet. If the outer layer of the plywood is hard glued, then the inner/opposite layers will want to shear away under stress.
Maybe someone with more expertise can comment. I was leaning towards titebond III or similar for my all-wood build (not a foamy),
Thanks,
Doug
DougN
Images: 26
Re: Glue for wood-to-wood - Hardening or Non-hardening
Postby tony.latham » Sat Mar 14, 2015 2:52 pm
DougN wrote:My local plywood supplier suggested that a non-hardening glue would be better as hardening glue can cause plywood delamination over time due to expansion/contraction /vibration of the sheet. If the outer layer of the plywood is hard glued, then the inner/opposite layers will want to shear away under stress.
Thanks,
Doug
Doug:
I've been working with wood for over fifty years and have never heard of this issue. In fact, I don't even know what he means by a non-hardening glue. The glue used to laminate plywood -phenol-formaldehyde- seems cure as hard as a rock. Perhaps some body else can straighten me out on this.
A proper wood joint will not fail with either Titebond 2 or 3 (the wood will fail first). I prefer TB2 since it'll stick to previously exposed surfaces with TB2 but you can't do that with TB3.
T
Postby MtnDon » Sat Mar 14, 2015 3:11 pm
A glue that did not harden or dry completely would make a joint that was subject to creep over time. When we glue wood to wood with a PVA glue like titebond, and clamp it properly, we end up with a joint where the glue is stronger than the wood. If you break that joint the wood fibers will tear. IMO, that is much preferable to using a glue that leaves the parts to move. Using a PVA glue once the joint is cured / dried the joint may be stronger than the fasteners, especially if the fasteners are a few finishing nails.
MtnDon
Images: 24
Postby DougN » Sat Mar 14, 2015 7:21 pm
Thank you for the detailed responses! The lumbar guy must have misunderstood my intended usage. Titebond II it is! Picked up a small bottle to experiment with.
DougN
Images: 26
