Axle location/Spreadsheet
Postby TNSean » Wed Apr 22, 2015 10:19 pm
When using the spreadsheet to figure out axle location, tongue weights etc.....
What approximate weight value would you use for the galley?
I am using 75lbs for a 100ah battery in enclosure to figure out if I am going to mount it in the galley or on the tongue (most likely on the front), but I am not sure how much to use for everything else in the galley.
Anyone want to take a guess of how much weight you carry in the galley? Maybe with an ice chest and without.
Thanks for providing the spreadsheet, it is a big help.
http://www.angib.pwp.blueyonder.co.uk/t ... tear81.htm
I am building a 5'x8' benroy on a NT bolt together 5'x8' trailer.
TNSean
Re: Axle location/Spreadsheet
Postby Socal Tom » Thu Apr 23, 2015 6:32 am
I added up the weight of the gear using weights from Amazon and the like. For the cooler, you can probably figure about one pound per qt of volume.
Socal Tom
Postby TNSean » Thu Apr 23, 2015 11:34 am
After running a bunch of different numbers I am going to go with 35" from rear. Seems the most flexible. After I build I will weigh and adjust loading as needed.
TNSean
Postby bobhenry » Thu Apr 23, 2015 12:11 pm
64% forward of axle and 36% rearward a good combination that should have great highway manners and should even back well.
