Semi-off-road frame/suspension
Postby bknowles86 » Fri Jun 05, 2015 12:19 am
Hey guys new to the forum. I am looking to build a custom teardrop to be pulled behind my Xterra. I don't do much serious offroading, and if I do, I plan to leave the trailer at camp. I'd like the option of pulling it along on some dirt roads and want it to look good behind my Xterra, so I'm thinking 31" wheels to match and a little bit of suspension, nothing serious. Anyone have any suggestions on frame/suspension?
bknowles86
Re: Semi-off-road frame/suspension
Postby noseoil » Fri Jun 05, 2015 7:40 am
Don't do the actual "off-road" stuff, just dirt roads myself. Many people who use off-road have the same tire & wheel size on the tow & trailer, so they have plenty of spares if necessary. Also, try to have the same frame clearance as the tow vehicle, so if the TV makes it, the trailer will also. As far as actual suspension components are concerned, I'm sure the people who do off-road builds will have some good suggestions for you. Welcome!
137905
noseoil
Images: 670
Postby Dale M. » Fri Jun 05, 2015 8:50 am
Might want to look at the TD on this website.... IT was made for what type of camping you describe...
http://www.outbackteardrop.com/
Dale
Dale M.
Images: 18
Postby wavebreaker » Sat Jun 13, 2015 9:42 am
I run timbren axleless suspension on my offroad tear with 33 inch tires. frame is a welded unit bolt together wont take the shake rattle and roll of washboard gravel etc.
wavebreaker
Postby bknowles86 » Sat Jun 13, 2015 4:15 pm
Thanks wavebreaker, really nice build BTW! I really like the look of the sawtooth as well - am looking at doing a much simplified version once I finally get around to it.
bknowles86
Postby bknowles86 » Sat Jun 13, 2015 4:18 pm
I meant to ask: are your sides 4' or 5' high?
bknowles86
Postby kayakdlk » Sat Jun 13, 2015 5:19 pm
My recommendation (Timbren) http://www.tnttt.com/viewtopic.php?f=35&t=57134
Good luck with your build
Dan
kayakdlk
Images: 392
Postby wavebreaker » Sun Jun 14, 2015 9:18 am
bknowles86 wrote:I meant to ask: are your sides 4' or 5' high?
sides are 4 foot
wavebreaker
