Sunroof
Sunroof
Postby bknowles86 » Sun Jun 07, 2015 5:42 pm
Has anyone had any luck installing a sunroof? I see that several people have asked the same question, and C R Laurence keeps coming up – just wondering if anybody has had any success with these. Thanks!
bknowles86
Re: Sunroof
Postby Prototear » Mon Jun 08, 2015 12:08 am
I am in the midst of installing one now on my build. It is a CR Laurence 22" x 38" and it seems well made. I can make it work but the curve has worked against the contour of the teardrop body. :thinking:
I have some pictures in my build journal and will be adding more later tonight. Those pictures are from last June but I worked on it just yesterday. My plan is to use the sunroof frame to clamp the roof skin before I attach the skin to the teardrop frame rather than fight the sunroof fitting to the skin after the skin is attached. I'm thinking I'll also need to add a removable screen to keep the sunroof open or off at night to keep the bugs out. It has a lip in the inside edge of the aluminum frame that I may be able to use, or perhaps I'll do something that attaches to the ceiling outside the bounds of the sunroof frame. That is a detail I'm not ready to work through yet until I get the bigger things installed.
I got it from Amazon and it was shipped by a company that seemed to be out east but the thing arrived quickly (I live a few miles north of Seattle) and its shipping info showed it as coming from Tukwilla WA, just on the other side of Seattle.
If I could do it over again, I'd consider a sunroof that curves in the same direction as the trailer body contour, or plan to install it in a flat area of the roof. The sunroof has a curvature left to right with the center being about 3/8" higher than the far left and right, and there is no curvature fore/aft. Meanwhile, my roof has no curvature left/right, but about 1/2" fore/aft since it right where the front curve of the body starts to descend.
First Build: viewtopic.php?f=50&t=57021
Prototear
Images: 412
Re: Sunroof
Postby Gage » Mon Jun 08, 2015 2:42 am
I don't know about CR Lawrence. I installed a sunroof I picked up at the local junk yard. It came off a 73 Chevy. Cost me $75.00. My roof is 1/8" Burch ply with .060 alum skin. The sun roof pulled the roof right in, no leaks except for when I forget to close it when it rains. :o
Image Image Image
Gage
Images: 28
Re: Sunroof
Postby bknowles86 » Mon Jun 08, 2015 8:50 am
Thanks for the detailed response Prototear – that is very helpful. Gage, did you have the same issues with your sunroof or is it pretty flat?
bknowles86
