Building Sides
Building Sides
Postby ToadSprockett » Tue Sep 01, 2015 1:00 pm
I've read a good amount of pieces on building sides, but with so much information making a decision isn't easy :?
So here's what I need, the sides need to be 5x10 at a minimum, I can get 5x5 birch and spline it together, which is OK but I wanted to do a glue up of 1/8" exterior, 1/2" internal (with routing for insulation and wiring), and then 1/8" hardwood lam on the inside (cherry in our case). So the 1/2" birch would be covered up, and the extra cost seems like a waste, I was considering just some good 1/2" ply in 4x8 sheets, maybe marine grade.
You can't get the 1/8" in anything but 4x8, and I'm really thinking a woody exterior would be awesome. So that leaves me with some questions...
Is there a good way to join 1/8" pieces to stretch them?, or should I just glue it to the internal ply?
Joining 4x8 pieces is not hard, but the seams would be an issue, I don't want a seam on the door, or have the exterior and interior plys on the same seam...
This is the first time I've confused myself with this :shock:
And before anyone says something about the insulation, we do VERY cold weather camping, so it really is needed...
Thanks
-Paul-
ToadSprockett
Re: Building Sides
Postby dales133 » Tue Sep 01, 2015 4:26 pm
Mines stick frame but the same principal should apply for your method.
Mines a shade under 10 foor and i have the internal 6mm ply joined in the galley (mostly because i used the door cutouts for the xtra lenth so i didnt need a 3rd sheet of birch)
The external ply is joined on the door center.
Ive laminated the ply on with sikaflex and lap jointed the 6mm but just butt jointed the 1/8 (3mm)
Providing youve got good backing behind the join and sand them dead flush when dry it will look fine
dales133
Re: Building Sides
Postby tony.latham » Tue Sep 01, 2015 10:03 pm
Paul:
Insulation? I get that.
I'm a big supporter of Steve Fredrick's Teardrop Builder's Shop Manual: http://www.campingclassics.com/shopman05.html (Disclosure: No association with him.)
The best thing that ever happened to me, from a builder's standpoint, was that I decided to purchase a copy before I started cutting on my first teardrop. It's 269 pages. He solves a lot of problems and addresses how he tackled a woody with a 5x10' profile. I think this is it here:
Steve: Did I just violate the copyright laws?
http://www.campingclassics.com/diner8.html
Re: Building Sides
Postby ToadSprockett » Tue Sep 01, 2015 10:06 pm
I am in LOVE with that teardrop, that is so AWESOME... Now I more than ever want to do a woody...
I'll pick up his manual tonight and start reading.
Thank You.
tony.latham wrote:Paul:
Last edited by ToadSprockett on Tue Sep 01, 2015 10:10 pm, edited 1 time in total.
ToadSprockett
Re: Building Sides
Postby tony.latham » Tue Sep 01, 2015 10:07 pm
That was quick...
Just what's on his website and in the manual.
