Does anyone have a good affordable source for pre-painted white Aluminum molding?
I have a color scheme going on and I think a mill finish would look weird. I am looking for a non vinyl option, aluminum trim that I can bend and not have to anneal.
noseoil wrote:You might look into an aluminum aerosol primer (spray paint). There are several made which will "etch" the surface & work pretty well. It may be better to shape the parts first, scuff, degrease with a thinner, then paint what you need to get a good finish on the parts. Aluminum is tough to paint, unless you use the right primer. For small stuff this might be the best way to go.
