Page 1 of 1
Spray Foam Insulation
Posted:
Wed Sep 09, 2015 9:28 am
by lrrowe
I just stumbled across this site for spray foam. Since I have already insulated my trailer, I did not take the time to digest the claims, but it just might interest others.
https://www.sprayfoamkit.com/?gclid=CJb ... HwodtlYOXQ
Re: Spray Foam Insulation
Posted:
Wed Sep 09, 2015 8:08 pm
by skinnedknuckles
I would be concerned about the expansion and what it may do to the surrounding wood or anything else that may try to contain it. Especially in a confined area.
Paul
Posted:
Thu Sep 10, 2015 7:03 am
by noseoil
It's a good product for insulating, but the biggest down-side I can see is with finishing the sprayed surface. I have a friend who uses this system to build homes & it's great for the insulating value R-factor, it works better than most other types of insulation on the market now. He's just finishing with sheet rock & standard wall finish, so no issues, but it's a real booger to deal with if the person spraying puts too much in place & it bulges out of the cavity. At that point it must be saw-cut & sanded to get a flat surface again.
No reason it won't work. It's being used more in the building industry with panelized construction techniques. Look up SIP wall systems in Google & see what you find.
Posted:
Thu Sep 10, 2015 10:02 am
by starleen2
The Northwestern was done with spray foam insulation
http://www.tnttt.com/viewtopic.php?f=50&t=29883&start=180 build journal
Posted:
Thu Sep 10, 2015 11:42 am
by lrrowe
That professional work looks, well, very professional. I am sure you will love it. I had investigated a professional job for my CT but thought the price was too high....something in the $888-$999 range.
Based on what I actually spent for EPS and other for the ceiling, it would only have been a few hundred more. Now I wish I had followed through with spray foam.
Posted:
Thu Sep 10, 2015 5:30 pm
by dogscats
I looked into getting one of these kits .The cost was high. Could do the same with 4 by 8 sheets and can foam. for a lot less .If you can get Nitrogen gas you can make your own 2 part kit. with 2 used through away party tanks
