aggie79 wrote:.... That said, if you partially lift you mattress during the day to allow air to circulate, any moisture from condensation should dissipate.
sincere01 wrote:The other thing to consider is though heated air typically rises as its less dense than air that is relatively colder, heat wants to dissipate from where there is more of it to where there is less. When you have air that can easily move under your trailer that is colder than inside, a lot of that heat will find its way thermal bridging through the plywood and being pulled away by the air moving underneath. A small layer of insulation can significantly minimize this effect.
kayakdlk wrote:I did it to save weight. I used 1x3 pine frame with 1/8 plywood on both side and 3/4 foam in between. My floor is 5'x10' and I could easily pick it up. With the SIP panel construction I could also stand on it.
Dan
