by KCStudly » Thu Nov 05, 2015 8:42 pm
I guess it is feasible, but you would have to look at the total weight of the finished cabin vs. the surface area of the trailer frame vs. the load bearing capacity of the specific foam you intend to use. Then you would also want to analyze any lack of uniformity of your loading (i.e. say the galley is especially heavy, you would want to look at the local effect of weight/surface area/capacity).
If the surface area of the trailer was insufficient or marginal, you could, in theory use strips of lumber or ply that are wider than the trailer frame to extend the hard surface over a bigger area of foam.
But why? IMO, for longevity, the foam needs some protection against physical damage, water infiltration, mold, etc. Frankly, the foam is pretty fragile. You could do the PMF thing on the bottom, but I doubt it would cost any less than a sheet of underlay ply, and would be at least as involved to do.
My Build:
The Poet Creek Express Hybrid Foamie
TnTTT ORIGINAL 200A LANTERN CLUB = "The 200A Gang"Green Lantern Corpsmen
