Hi all, I am starting a 5x10 build on an HF 4x8. I have seen folks indicate that one way of doing this to avoid wheel wells is to start by joining 2x4s on end to the trailer frame. My question is how are the 2x4s attached? I can think of two ways. The first start from the top and put a lag bolt through the top edge of the 2x4 and through the pre drilled holes in the frame then secure with nut from inside the frame Chanel. Or starting from bottom and use a self tapping screw from inside the frame Chanel through the pre drilled holes into the 2x4.
Please let me know what you think is the better approach or if there is another way all together.
Thanks you all!
