Edge Trim Bending
Hello all,
I am in the process of installing the sides on my teardrop. So far I've cut one side and ready to install it with contact cement. I'm just going to go around the perimeter of the trailer side, the doors and windows only. It doesn't get that hot or cold around here or where ever I'm going for the aluminum to warp. Sanded all the wood filling covering cracks and screw holes and already cut the aluminum sheet. I am in Delaware and after looking around all over I did find a place that has aluminum sheets that are 10'x5' just down the road from me. After checking in Maryland, Pennsylvania and New Jersey all over the net. Rierson is the place in case any body needs the info. They have a minimum of $300.00 sales purchase. 10'x5'x.050" are the sheets I purchased. Now here comes the question. I went with the teardrop pattern which has that radius in the front and end. Where can I purchase the edge trim and the real question is how do I bend it around the edge with out crimping it?
Any help will be appreciated.
Thank you
Carlos
Thank you
Carlos
