Steel siding?
Yes, I know this is going to sound nuts! I am wondering if anyone has ever used steel siding for their teardrops or other travel trailers for a skin? I realize it is about 2.5 times as dense than aluminum, but thin gauge would hold up better against rocks, hail, and such when compared to aluminum. It appears to be much cheaper per sq. ft. I can get it in about 20 different colors, all with a 40 year warranty. It is 29 gauge and they want about $3.12 per linear foot at 40 7/8 inch wide. It is local, and they can do any length up far beyond what I could ever need.
I know seams would be a issue, I would end up with seams either vertically or horizontally. Is there a way to seal the seams? I have a enclosed cargo trailer I rebuilt the frame for, not sure what they used for the sides but a magnet won't stick to it. I assume aluminum also. They used vertical seams, with the front pieces on last, and the first one on were the rear. The end of each panel, over lapping about 2-3 inches. I never seen any leaking of any kind at the seams. Has anyone used used a method of sealing seams on a roof that is wider than normal? My roof currently is looking at about 6' to 6'6" wide.
I know it will be heavier long run, but I am also pulling with a 3/4 ton truck, my idea is based on a gooseneck trailer design. Thanks! - James
