Port Hole Window
Port Hole Window
Postby ToadSprockett » Tue Jan 26, 2016 11:55 am
I'm putting in a large porthole on the side of the teardrop, the only question I have is how do I install the window to be watertight?
Right now I just have the hole cutout in the frame, once I sheet the outside, I can make a lip or whatever I need.
Any advice?
Thanks
-Paul-
ToadSprockett
Re: Port Hole Window
Postby noseoil » Tue Jan 26, 2016 2:23 pm
I bought store-bought for this reason. Too hard & time-consuming to reinvent the wheel.
If you look at automotive type window moldings & the string trick, this might help. It would still be a lot of work compared to buying off-the-shelf, IMHO.
137905
noseoil
Images: 670
Postby KennethW » Tue Jan 26, 2016 2:29 pm
have you looked at wiley windows. They work great and are low cost and easy to build.
viewtopic.php?f=2&t=65171&p=1158986&hilit=window#p1158781
KennethW
Images: 82
Postby KCStudly » Tue Jan 26, 2016 7:23 pm
So that begs the question, do you want them to be opening or fixed, screened or non?
Postby rowerwet » Wed Jan 27, 2016 6:35 am
The gama seal window is another possibility, I plan on a removable inner plexiglass pane for mine
rowerwet
Images: 521
Postby rowerwet » Wed Jan 27, 2016 6:41 am
http://www.wesleywindows.co.uk/index.php?id=8 these work, but shipping is expensive
rowerwet
Images: 521
