Wall construction question
Postby Osage Outlaw » Wed Feb 17, 2016 2:51 pm
I'm starting on a 6'x13' teardrop shaped camper on a dual axle trailer. It will be roughly 6' tall inside. I stopped and bought some 2"x2" lumber for studs and some thin plywood to frame up the side walls. I've been browsing through some of the build journals and noticed that most side walls are made from thicker plywood and no studs. Since my camper is bigger I thought I would need the studs. Now I'm not so sure. I plan on covering the outside in old barn siding. Any advice or suggestions would be appreciated.
I started out with nothin' and I still have most of it left.
Osage Outlaw
Re: Wall construction question
Postby Jeff Myers » Thu Mar 24, 2016 12:30 pm
Osage Outlaw,
I am about to build a similar size trailer. What was your decision on the wall construction?
Jeff Myers
Postby halfdome, Danny » Thu Mar 24, 2016 4:22 pm
Maybe you could get some inspiration from here.
He's 17 miles from us and I've seen him make recreations with 2x2's.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby dales133 » Fri Mar 25, 2016 5:22 pm
3/4" × 1 1/2 - 2 " should be more than enough if you glue the interior and exterior skins to it
dales133
