Page 1 of 1
aluminum in Nor Cal
PostPosted: Thu Mar 17, 2016 5:42 pm
by mariannf
Hi all,
Does anyone have suggestion about where to buy aluminum sheet in Nor Cal? I have a 5x10x5 design, and am only putting aluminum from end to end over the roof...so i will need a 20 foot sheet that is 5' wide. i have sub roof materials (3mm birch) so want a low gauge thickness.
any suggestions appreciated!
Re: aluminum in Nor Cal
PostPosted: Thu Mar 17, 2016 7:23 pm
by Redneck Teepee
Any sheet metal shop can order it in for you, or tell you where to order from, if the supplier sells to the general public. :D
PostPosted: Thu Mar 17, 2016 10:53 pm
by mariannf
thanks!
PostPosted: Fri Mar 18, 2016 6:17 am
by Dale M.
Depending on where you cal Nor-Cal...
http://www.all-rite.com/siding-c-30.htm ... 7f7ca02ac7
Dale
PostPosted: Fri Mar 18, 2016 11:13 am
by mariannf
Dale M. wrote:Depending on where you cal Nor-Cal...
Dale
Thanks Dale!
PostPosted: Mon Mar 21, 2016 2:25 pm
by DaveS
Coast Aluminum in Hayward
http://coastaluminum.com/contact/
I bought 5x12 sheets of .032 thick 5052 from them. They had it in stock Figured sheets would be easier to handle/install than coil. Make sure you ask to have protective film put on one side. Was no additional cost and saved me a couple of times.
PostPosted: Mon Mar 21, 2016 4:55 pm
by vegask
SAF in Redding. Ask for David Emry if you need a sales rep. Shipping/freight is free on anything over 100lbs and they do anodized finishes.
PostPosted: Sun Mar 27, 2016 11:58 pm
by SC Campbell
I get my aluminum from Cardo Industries in Sacramento
1054 El Camino Ave, Sacramento, CA 95815 · (916) 922-7824
cardoindustries.com
PostPosted: Mon Mar 28, 2016 10:15 am
by mariannf
SC Campbell wrote:I get my aluminum from Cardo Industries in Sacramento
cardoindustries.com
Thanks!
