In particular, what I'm using is "Foamular 250" from Owens Corning. It is made from "Polystyrene" and the instructions on the PL adhesive says not to use it on "Polystyrene bath tub surrounds, Polyethylene or for polypropylene applications requiring water immersion."
It also says "Adheres To: Foam Insulation."
This is not a "wataer immersion" application so I'd think it should work.
I've glued up a small sample and I've seen no adverse effects although it has not thoroughly cured yet.
Any thoughts or experiences you'd like to share?
Thanks,
