Re: remind me. temp on working epoxy resin.
It will vary by product, but for West System I have found that the "Fast" 205 hardener is good to apply down to about 45 deg F and can be used for smaller layups up to about 68 deg F, if you work quickly, or for small thickened spot fill jobs.
For bigger layups, first time users, and/or hotter temps move to the 206 "Slow" hardener. The 'slow' is okay at lower temps, too, it just takes even longer to kick.
YMMV with conditions and differences in technique.
I have mostly been laying up 2 plies of 6oz cloth over foam board or wood, and seldom do layups of more than about 4 sq yds area. For larger layups I have been working dry on dry, usually pushing the epoxy thru both plies at the same time.
