How big of a box on tounge do I need for my battery
Postby dogpound101 » Mon May 09, 2016 11:31 am
Had a trailer made made and threw put the tongue jack to close to the frame
Is 12"x20"x 12"tall ok?
141474
Doug
dogpound101
Re: How big of a box on tounge do I need for my battery
Postby lfhoward » Mon May 09, 2016 1:41 pm
It depends on the size of battery you plan to use. A group 24 size is 7 inches wide, 11 inches long, and 9 inches tall (ish). A 24 inch long box would fit two of these, but a 20 inch long box would not.
I am in the midst of modding a 12x30x12 box to fit 3 batteries. Details here:
http://www.tnttt.com/viewtopic.php?f=50&t=62581&start=315#p1170469
lfhoward
Postby KCStudly » Mon May 09, 2016 3:22 pm
...or just move the jack further forward and build a larger TB so that you can fit the battery and other useful items, both.
If it can be built, it can be rebuilt. Don't let a simple design misjudgment snowball into multiple compromises. Fix it the way you want it to be now. $0.02.
Postby noseoil » Tue May 10, 2016 7:35 am
12 x 20 x 12 is fine for a single battery, what Lauren said. No reason it won't work, but as KC said, you could always relocate the jack & have a bigger box.
What's the biggest thing you need in the tongue box & what else goes inside? If there isn't enough room for your plans, move it forward to open up more room, if not, just use what you have. A group 31 battery is about 7" X 9 1/2" X 13" so the box would fit a bigger battery, but not a lot of everything else.
137905
noseoil
Images: 670
Postby dogpound101 » Tue May 10, 2016 9:05 am
Thanks guys I think I will move it foward
Doug
dogpound101
Postby Gettin Started » Tue May 10, 2016 1:09 pm
If the crank (handle) on the jack is still in the way due after moving it forward (i.e interferes with the tongue box), consider a side-winding jack. It takes more turns of the handle to move the jack up and down, but a $30-$40 investment in this might save frustration and make your tongue more usable.
Gettin Started
Images: 15
Postby dogpound101 » Sat May 14, 2016 9:09 am
I moved the jack foward today
http://oi63.tinypic.com/dher8h.jpg
Doug
dogpound101
