Painting aluminum trim
Postby rooster » Sun Jan 15, 2006 3:35 pm
Hey guys and gals; My tear is polar white aluminum. If I use regular aluminum trim and want to paint it, is there someting I have to do to it before I paint it white?
Jim, :thinking:
Beware of what she wishes....especially with that twinkle in her eye and that mischievious smile....you know it's gonna cost....
rooster
Images: 42
Postby doug hodder » Sun Jan 15, 2006 3:47 pm
You'll need to scuff sand it with something like 150...just to give the primer a "tooth" to attach to....you could also do an acid wash on it...but for the size of the pieces...sand paper is a lot less mess and cheaper in the long run...just use fine enough paper that the primer will hide the scratches prior to shooting the top coat...and I would think that you will want to paint if after it is on the tear...depending on the radius you want to bend it could be a problem getting the paint to flex...you'll have to put it on...mask off the surrounding areas and paint the trim...test paint and bend a piece for practice ....Doug
Postby Rick Sheerin » Sun Jan 15, 2006 4:33 pm
Did you ever consider having the parts powdercoated? It would be a lot more durable than painting them.
Rick S
1996 Casita Spirit Deluxe 17ft
Careful with that Axe, Eugene
Rick Sheerin
Images: 100
Re: Painting aluminum trim
Postby ssrjim » Sun Jan 15, 2006 7:27 pm
rooster wrote:Hey guys and gals; My tear is polar white aluminum. If I use regular aluminum trim and want to paint it, is there someting I have to do to it before I paint it white?
Jim, :thinking:
You need a special primer.
93079
ssrjim
Postby alaska teardrop » Sun Jan 15, 2006 8:47 pm
Hey Rooster - Is your rig still Polar White or looking a little like Grey Volcanic Ash? :lol: Fred :snow
alaska teardrop
Postby doug hodder » Sun Jan 15, 2006 8:51 pm
As an ex-Alaskan...didn't hear...did Redoubt fart again? doug
Postby alaska teardrop » Sun Jan 15, 2006 9:18 pm
alaska teardrop
Postby rooster » Sun Jan 15, 2006 9:46 pm
Sorry Fred, no ash this time.
Jim, :applause:
rooster
Images: 42
Postby TRAIL-OF-TEARS » Mon Jan 16, 2006 2:58 pm
rooster,
you could install it to get the bends right then take it off and paint/powder coat then re-install. that might be easier than masking and over spray problems.
Also most RV places (at least around here) carry alum trim in the polar white only.
Steve J.
Home built Camp-Inn clone.
GO SPURS GO
TRAIL-OF-TEARS
Images: 41
