2 piece roof?
2 piece roof?
Postby RubberGypsy » Fri Feb 03, 2017 12:32 pm
Hi - I'm doing a re-build. While tearing off the roof I discovered that this Tear has 2 pieces of the top flooting roof.
Obviously, this is not ideal but, I thought I'd ask. How would you tackle this? Add another ply maybe and just cover over it?
Trash it and go w/ something else?
Originally it was joined w/a glued and screwed board on the top. Also, no edge trim (place of purchase recommendations?)
Here's my build thread:
viewtopic.php?f=50&t=67838
And a link to my google pics:
https://drive.google.com/open?id=0B18se ... 2pfZXBqTnM
I've considered skinning the thing but,
1. I want to run new wires
2. Add insulation
3. Wanna clean any mold
4. I don't trust the original contstruction
and as you can see from the pics, I really need to get in there and check this out.
Thank for any comments!!
Andy
RubberGypsy
Re: 2 piece roof?
Postby Andrew Herrick » Thu Mar 02, 2017 12:39 am
Hey! Checked out your pictures. Am I understand you correctly that that original trailer had NO exterior roof skin? Just the plywood? And that the plywood is only secured by screws along the perimeter? And that two pieces of plywood (looks like varnished lauan) were used to seam the roof?
If so ... well ...
Yeesh.
But, we all gotta start somewhere! So I'll give the original builder the benefit of the doubt.
-No matter what you do I'd seal the edges of that wall plywood. Water wicks 15 times faster through the edges of plywood than the face.
-Personally, I think lauan is only appropriate as an underlayment or sheathing, not an exterior. If you only need two sheets, why not okume marine plywood?
What sort of exterior are you gunning for?
A few of my builds:
SEE MORE AT: boondockcampers.com
Andrew Herrick
Images: 15
Re: 2 piece roof?
Postby swoody126 » Thu Mar 02, 2017 9:33 am
RG, I WILL ATTEMPT TO ANSWER YOUR Q'S IN ALL BLOCK CAPS TO SEPARATE YOUR WORDS & MINE
beginning of quote="RubberGypsy" Hi - I'm doing a re-build. While tearing off the roof I discovered that this Tear has 2 pieces of the top flooting roof.
THIS METHOD OF TOPPING IS NOT UNCOMMON, IMHO
WE USE IT FOR PANELS OF BOATS THAT ARE TOO LONG FOR ANY READILY AVAILABLE PLYWOOD WE JUST KEEP THE BLOCKS ON THE INSIDE
SOME READING FOR YOU(KNOT KNOWING YOUR TOOL AVAILABILITY AND SKILL LEVEL I AM INCLUDING MORE THAN ONE OPTION W/ PICS):
http://www.amateurboatbuilding.com/arti ... y/ply.html
http://www.oneoceankayaks.com/stitchglu ... rfjig2.htm
"BUTT BLOCK" JOINTS ARE COMMON AND VIABLE WHEN DONE CORRECTLY AND KEPT PAINTED FOR PROTECTION FROM THE ELEMENTS
"DWX" EPOXY FROM "DUCKWORKS" IS WAY LESS TOXIC AND HAS "UV" INHIBITORS BUILT INTO THE FORMULA WHICH WOULD BE A GOOD PRODUCT FOR YOUR PROJECT
http://www.duckworksbbs.com/supplies/ep ... /index.htm
ROOFING A TEARDROP AND INSTALLING A BOTTOM ON A BOAT HAVE VIRTUALLY THE SAME GOAL, KEEPING THE WATER OUT
LACK OF EDGE PROTECTION IS A PRIMARY SOURCE OF ROT/FAILURE(DUH!)
EPOXY COATING OF EDGES HELPS A LOT
ALL AFFECTED WOOD NEEDS TO BE REMOVED IF YOU WANT TO DO IT CORRECTLY
ONCE THE AFFECTED STRUCTURAL WOOD HAS BEEN DEALT WITH, EXCISED/REPLACED OR SUBSTANTIALLY PATCHED, RE-ROOFING W/ 2 LAYERS OF EXTERIOR GRADE OR PREFERABLY MARINE PLY WHERE YOU STAGGER THE JOINTS AND FULLY GLUE THE LAMINATION. USING SCREWS MAY NOT BE NECESSARY IF YOU GET YOUR LAYERS PROPERLY BONDED AND ALL EDGES N JOINTS PROPERLY SEALED
ANYWHERE YOU HAVE PLYWOOD EDGES EXPOSED TO THE ELEMENTS YOU ARE INVITING FAILURE
THESE PICS INDICATE WATER INTRUSION AND THE AFFECTED WOOD NEEDS TO BE ELIMINATED, BEST, OR AT LEAST STABILIZED, SO-SO RESULTS
USING METALIC FASTENERS IN PLYWOOD EDGE GRAIN ISN'T SOUND PRACTICE
CONSIDER ADDING CLEATS INSIDE IF YOU WANT A SIMPLE OUTSIDE CORNER OR ON THE OUTSIDE OF THE WALLS TO PROVIDE A LIP EFFECT WHICH MAY GIVE THE EDGES OF THE WALLS BETTER PROTECTION
ONCE THE STRUCTURAL DAMAGE HAS BEEN REPAIRED SKINNING OR FIBERGLASSING MIGHT SUIT YOUR TASTES
2. Add insulation
1, 2 & 3 ARE ALL EASILY ACCOMPLISHED DURING THE STRUCTURAL REPAIR STAGE
ABSOPOSOLUTELY!!!
KEEP DIGGING UNTIL YOU PASS ANY AFFECTED WOOD
THEN START THE REPAIRS
Andy, end quote
GOOD LUCK W/ YOUR QUEST
sw
swoody126
Re: 2 piece roof?
Postby Andrew Herrick » Thu Mar 02, 2017 9:49 am
swoody126 wrote:RG, I WILL ATTEMPT TO ANSWER YOUR Q'S IN ALL BLOCK CAPS TO SEPARATE YOUR WORDS & MINE
sw
+1 on this answer.
To add a little information: If you must drill into the edges of the plywood, there are a couple easy ways to reinforce the connection. You can use a 1-inch hole saw bit and drill in a 1-inch hole from the side, plug it with hardwood, and then insert the screw through the end grain so it enters the hardwood plug. That will give it some bit. You can also drill a pilot hole, fill it with epoxy (there are certain kinds, I'm not sure which to recommend), and then drill into the epoxy.
If you don't use any other reinforcement ... Let's see ... use fine-thread wood or sheet metal screws and always predrill your holes.
Good luck!
A few of my builds:
Andrew Herrick
Images: 15
Re: 2 piece roof?
Postby KCStudly » Thu Mar 02, 2017 4:15 pm
Rather than drilling and screwing into epoxy, if you wax your screws you can "pot" (cast) them in place when you place the epoxy filler. This method is actually recommended by West System. After the cure pull them out and fasten. This casts the thread right into the epoxy. I used this technique when repairing some of my hatch hinge screw holes, just be sure to put them in the right place!
Re: 2 piece roof?
Postby RubberGypsy » Thu Mar 16, 2017 10:58 am
Big thanks to all who replied here. Lots of useful info. What a great community
Sent from my MotoG3 using Tapatalk
RubberGypsy
