A Dark Horse - Oscillating Multi Tool
I admit it: I'm a tool junkie. It all started with an estate sale years ago, where I picked up an old radial arm saw (recalled), a 1960's table saw (no guard blade), three-legged router table and buzzy Chinese-made palm sander, for a grand total of $10. I've upgraded hardware since, but I still feel that craftsmanship means having the right tool in your hand. If you prefer the purity of hand tools, well, you're a better/more patient man than me
Anyways, in all my readings on this wonderful site, I've rarely come across mentions of an oscillating multi-tool, and as a new owner myself, I wanted to alert maybe some first-time builders to this inestimable tool. It's the third hand you've been waiting for. You probably already know that in order to build a simple teardrop you need a drill, jigsaw, circular saw and sander. I would add an oscillating multi-tool, like a Rockwell Sonicrafter or Dremel Multi Max, to that list. It's a lifesaver for plunge, flush and trim cuts, all of which are extremely awkward and/or dangerous with a jigsaw. I've experienced almost no kickback with an oscillating multi-tool; can't say the same for a jigsaw.
I've used mine to trim a hurricane hinge, flush cut shiner screws, cut electrical box openings, sand wooden trim, kerf short dado joints and flush trim sheet metal. And I'm sure there are dozens of other uses waiting to be discovered.
Bosch, Grizzly, Fein, Rockwell, DeWalt, Milkwaukee - lots of good brands making these things. Corded and battery-powered. $50 to $200 (with accessories).
Alright, commercial's over. Hope this helps saves someone else a headache. Good luck!
