Last Minute Suggestions?
I am basically done with my build finally and i'm happy with the way it is turning out! Any Last minute suggestions from an experienced teardropper???
or t n ttt for short (tnttt.com)
https://www.tnttt.com/
I can't make out what's in your photo. Is it just me? Perhaps if you loaded a better photo, we could make suggestions.curtybird95 wrote:I am basically done with my build finally and i'm happy with the way it is turning out! Any Last minute suggestions from an experienced teardropper???
working on it wrote:I can't make out what's in your photo. Is it just me? Perhaps if you loaded a better photo, we could make suggestions.curtybird95 wrote:I am basically done with my build finally and i'm happy with the way it is turning out! Any Last minute suggestions from an experienced teardropper???
Pinstriper wrote:I am in no way an experienced teardropper, but 2 things stand out to me in the photo.
1 - This looks like the foldable HFT trailer, and secured with the pins and clips. If those were removed, does your build survive the frame being folded ? May be possible to tack weld the frame open, or at least put a nut/bolt with red loctite to make it permanent.
2 - Consider a drip shield above the door ?
Oh, and
3 - That front surface is begging for a solar collector
4 - A porch light next to the door ?
5 - Does the door have a lock ?
6 - Where do you carry the spare tire ?
working on it wrote:working on it wrote:I can't make out what's in your photo. Is it just me? Perhaps if you loaded a better photo, we could make suggestions.curtybird95 wrote:I am basically done with my build finally and i'm happy with the way it is turning out! Any Last minute suggestions from an experienced teardropper???
- It was just me; I've been having problems with my PC for a long time, but everyday, there's another....
- I agree with Pinstriper about all his suggestions, and will add some more. If you don't have a screen for your window, you'll need one, sooner or later, and you have loose wiring on the front of your frame. In my experience, any loose wiring will get ripped away, whenever possible. I've seen kids tear them off, just for kicks. Secure them out-of-sight on the underside of the angle, for security. I also don't see stabilizers under the rear of your trailer; you can use short jack stands underneath, or leave your trailer hitched to your tow vehicle, if you camp before adding any. I'm sure you'll find some things to add/change with every trip you take; I do.
