Fredericks Style Hatch Question
Morning TNTTT
I know .. another hatch question. Sorry, I am getting closer to building the hatch and I may have already messed up
In the book he had both the inside skin and the outside skin glued on when he cut out the side for the hatch. I didn't have the inner skin on my wall when I cut the sides out for the hatch. I added the 1/8 spacer then glued and screwed the inner 3/4 piece for the gasket. When I hold the pieces together it seems like there will not be enough gap between the side of the hatch and the 1/2 in inner wall.
I hope this makes sense. Maybe a pic or two will help
This is side wall. I took a pen and tried to draw the separation lines between the inner 1/2 wall and the 1/8 spacer and outer walls. So you can see from left to right, the 1/2 inner galley wall, the 1/8 spacer, the 3/4 skeleton wall and the 1/8 outer skin ( I know .. it needs some sanding and some epoxy filler too)
This is the hatch sitting on the wall. Again I tired to use a pen to highlight the layers. Again from left to right, the 3/4 inch spacer, 3/4 outer wall and 1/8 skin.
Question is can I just add another 1/8 layer to the inside of the hatch ? Or will I need to rebuild this with the spacer in the proper place?
Or will it all work out since I didn't have the inner skin on both pieces?
Any help you can give is VERY welcome
