FINALLY...Progress on the Squidget with PICS to prove it!!!
By Golly, I have what almost looks like a trailer frame. I am just cutting and dry fitting the pieces, but I’ve posted them in an album. Later, after the welding is done, I’ll replace these pics with the completed frame progress. Before someone tells me that the tongue should be under the frame, not on top, the entire frame is upside down, except for the coupler mount and coupler. I have it sitting on what is the bottom of the tongue, just to fit the pieces together to make sure everything is cut properly. I still have lots of grinding to do, to smooth some cuts and refine all of the bevels for the weld bead.
I thought about making a bumper of wood, mounted on a frame of angle iron, but decided finally to make it of steel, but it’s not done yet. I’m still deciding on the design. That will add more weight, but also more protection. If I’m going to have a bumper, it may as well do the job and wood might look good, but I doubt it would win over a vehicle crashing into it.
http://pg.photos.yahoo.com/ph/cracker39 ... dd&.src=ph
